Sagging floor C2
  • Albert P.
    • April 1, 2006
    • 205
    Sagging floor C2
    Has anyone repaired a sagging floor in a C2 in the area of the rear end? Can it be done with body on? How difficult a job is it? What's needed for the job? Anyone have any pictures? Thanks.
  • Joe C.
    • September 1, 1999
    • 4601
    Re: Sagging floor C2
    Garth,
    I have repaired holes in the floor in the areas near the rear end. While it is possible to repair with the body on, of course it will make for a better job if the body is off. A correct repair requires laying on of glass matting and resin from above and below. After curing, it can be sanded to the proper contour, and will be practically undetectable. Here are a few shots of repaired areas before sanding and painting:
    Here's why the repairs were so easy to do:
    • Joe C.
      • September 1, 1999
      • 4601
      Garth,
        • 42936
        GARTH------
        Paragon sells for a nominal price a set of instructions for this repair. I think that the repair methodology was worked out by Dick Fortier.
          • 42936
          GARTH------
          • Albert P.
            • April 1, 2006
            • 205
            Thanks guys! *NM*
            • Albert P.
              • April 1, 2006
              • 205
              Thanks guys! *NM*
