1969 427/390 Fan Clutch - NCRS Discussion Boards
  • Salvatore I.
    • April 1, 2004
    • 114
    In need of some guidance in locating a correct, dated fan clutch for a 1969 427/390 engine or a lead on a supplier who can correctly rebuild my existing fan clutch that is on the car.....
    How can I tell if the one on the car is the original and not a replacement?
    The advice is appreciated!
    Re: 1969 427/390 Fan Clutch
    Sal-----
    Well, the very first thing to check is the fan clutch mounting flange (where it "bolts up" to the pulley). If the flange has SLOTS instead of HOLES, then you need check no further----you have an aftermarket, replacement fan clutch.
    Otherwise, the fan clutch originally used for your application was GM #3937771. It's also possible that other clutches were used, but this is the most likely. These clutches usually have a date stamped on them on the periphery of the mounting flange, so, if you have an otherwise correct clutch, that will tell you if it may be original to the car or a later replacement.
    A photo of the face of a GM #3937771 is seen below.
      Sal-----
      • Henry A.
        • May 31, 1990
        • 103
        I have one...that is dated 1 28 67. This may be to early, but may work.
        Henry Atsma
        54 White/Red
        63 Red/Black SWC
        67 Elkhart Blue/Black BB Roadster
        91 Black/Red ZR1
        96 CE - LT4
        07 Red/Tan
        • Henry A.
          • May 31, 1990
          • 103
          Henry Atsma
          54 White/Red
          63 Red/Black SWC
          91 Black/Red ZR1
          96 CE - LT4
          07 Red/Tan
