I am trying to troubleshoot a headlight rotation problem which I suspect lies with the rotation switch. The headlights will not rotate up or down using the switch. However, if I open the headlights manually they will close using the switch. I disassembled and cleaned the switch but it did not help.
There is a thread on the subject dated Nov. 1, 2005 where Dale Schafer discussed the rotation problem and he mentioned taking a jumper wire and jumped across the terminals and ran the headlights up and down. Could someone please describe where the jumper connections are made so that I can perform this function to help determine if I have a rotation switch problem? Thanks for your help.
