Plug wire routing 65 sb - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    This may seem like a dumb quetion but, I need to know where the plug wires exit the forward opening of the lower V shielding to the spark plugs? Do they (wires 1-3-2-4) go between the motor mount and block (between upper 2 bolts) or sneak through the smaller but will work Rear. Either coice is possible. With the forward choice, getting the boots under the motor mount is tight on boot but not the wires. The rear choice is tight on the wire, but to change out at a later date would be easier. Simply loosen up the rear mount bolt to loosen up the V shield and slip wires out. How should they run? Thanks DG
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Plug wire routing 65 sb
    The front plug wires go through the motor mounts. They can be difficult to slide in but if you peel back the wire boot it is possible to get them in with out removing the motor mount bolt.
    • Dick G.
      • May 31, 1988
      • 681
      Thanks Bob. DG
