'69 427 Fuel Pump Push Rod - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    When replacing this (lost) rod, exactly what should I be asking for? Would you recommend I get it from GM or will rods from major auto parts stores be equal? Are there differences between 327, 350 and 427 rods? I presume engine horsepower rating has no bearing on rod configuration.
    My delimma is that the original owner had an electric fuel pump installed at the fuel tank and, I think although have not confirmed, that the fuel pump connection on the engine was covered with a gasketed flat plate. I did receive the initial pump with the car when purchased from the first owner. Evidently, he didn't retain the fuel pump rod.
    Thanks in advance for your input,
    Kent #6201
    Kent
    NCM Founder - Member #718
  • Mark #28455
    Re: '69 427 Fuel Pump Push Rod
    Get a GM one. You're never really sure what the aftermarket has to offer. You can get a stock one at your local dealer, or if you can't go there during business hours, order it from Scoggin Dickey @ SDPC2000.com
    P.S. The original may just be sitting in the block - you never know, just remove the 1/4" pipe plug and see.
    Good luck,
    Mark
    • Kent K.
      • December 1, 1982
      • 1139
      Thanks for the suggestion Mark. Please explain how a 1/4" pipe plug could possibly fill the void remaining from a missing fuel pump somewhat triangular gasketed surface on the block's side.
      Regards, Kent #6201
      Kent
      • Kent D.
        • February 1, 1992
        • 100
        You will find the 1/4" pipe plug just below the fuel pump mounting plate. You can remove it and the rod will slid out.
        Kent
        • Kent K.
          • December 1, 1982
          • 1139
          Thanks Kent for the lesson *NM*
          Kent
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: If you can wait a couple of days
            Hi Kent,
            I took one out of a 69 427 that I parted out years ago. I think I still have it.
            If I can locate it, you can have it for the shipping costs.
            Let me know,
            Chuck
            • Kent K.
              • December 1, 1982
              • 1139
              Chuck,
              Your offer is generous and I'll accept. Email me to let me know the cost of shipping.
              Kent #6201
              Kent
              • Chuck R.
                • April 30, 1999
                • 1434
                Re: Lucky Lucky
                Found it on the first attempt.
                I'll mail it out to you today.
                Chuck
                • Kent K.
                  • December 1, 1982
                  • 1139
                  Thanks a bazillion Chuck *NM*
                  Kent
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    Re: Merry Christmas
                    Oh if all my gift giving challenges were this easy.......AND affordable
                    Chuckster
