Confirmed that the plug wires were properly oriented on the cap. Found 6 deg. BTDC , confirmed rotor at #1 cylinder. Removed the distributor and examined the gear dimple vs rotor position. It checked. Rotated gear 180 deg. re installed the distributor. Timed the engine to 6 deg. BTDC -- distributor vacuum can now at mid point between can and intake. Car idles and accelerates great. Original distributor and gear. Service replacement cam. Maybe cam gear incorrectly machined.
Dave K.
Dave K.
