C1 - Generator Oilers--- - NCRS Discussion Boards
  • Collin MacDonald
    I have a close friend he does an excellent job restoring generators, alternators etc. Does anybody have a good source for the old oilers used for the Generators. The are like metal caps that a spring loaded lid. I need several new ones...anybody got a source?
    Many Thanks
    Re: C1 - Generator Oilers---
    Anyone rebuilding a generator today is using maintenance free bearings that require no oiling. As far as the press-fit oiler caps go, you can remove your originals and take them for a 'swim' in your home plating system to restore the original plated finish OR simply ask your local generator rebuilder to install fresh new ones... Most in the generator rebuild business have a supply in their small parts bin.
    • Michael L.
      • July 31, 2005
      • 562
      Collin, I had a hard time finding them believe it or not. BUT, pillow block bearings for evaporative coolers have the spring loaded caps just like the generator, I picked up two at Home Depot foe a few bucks each, removed the olier caps and tossed the bearings. Cheaper that the vendors and no shipping fees. They look fine and work the same...
      Mike
      • Verne Frantz
        What's a "pillow block bearing"????
        • Michael L.
          • July 31, 2005
          • 562
          Verne, it is a bearing that holds a shaft on a squirrel cage blower. The bearing is enclosed in a metal U shaped bracket that is bolted to a frame. It is usually cushioned with a rubber surround to dampen vibration. Most commonly found where you buy replacement parts for swamp coolers, but are probably used in other applications taht have cage blowers.
          • Verne Frantz
            Tnanks. I've been looking for a supplier for those oiling fittings.
            • Collin MacDonald
              Found a source:
              McMaster's in Ohio....look it up on the net...
              EXACT
              Collin
              • Verne Frantz
                Thanks Collin,
                McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                Catalog page 2041
                Should look like this
