Hi all !
I have a fast one for those of you knowledgeable with big blocks.
I am trying to determine if Tonawanda could have / would have made 4-bolt main
big blocks without the external oil cooling provisions being machined-in.
It has been reported that some applications got 4-bolt main blocks ( where
2-bolt mains were std. ) due to availability issues. In these cases, the
blocks may not have been drilled for the external oil cooling provision that
is std. with all 4-bolt main SHP blocks. I myself do not agree with this as
I believe that at the time of manufacture, there was no way to know if the
block would have been used for non-SHP applications. Furthermore, I suspect
that any block machined for 4-bolt main provisions would also have been
machined for external oil cooling. Can anyone here tell me if there were
exceptions to this "rule". Also, would truck or fleet BBC engines ( not tall
deck blocks ) fitted with 4-bolt mains also have the external oil cooling
provision? I know many of you have been around mark IV engines for decades
and I was hoping one or more of you have some first hand knowledge.
Steve
Steve
