63 shp timing - NCRS Discussion Boards
63 shp timing
  • jim cear
    63 shp timing
    Installed my 63/340shp distributor and am off one tooth, i.e. vac can is against manifold for 10 BTC. Which way do I rotate the shaft for proper clearance CW or CWW? Thanks
    Re: 63 shp timing
    Jim -
    Clockwise, as viewed from the top. One tooth will move the housing 27 degrees - if that puts the vacuum can against the coil (assuming the wires are indexed correctly in the cap towers), pull the distributor and move the drive gear 180*; the "dimple" on the gear should be pointed in the same direction as the tip of the rotor (with an original GM camshaft).
    • John D.
      • December 1, 1979
      • 5507
      Re: 63 shp timing
      Jim, About two weeks ago your type question was discussed extensively. Question was posted by Dave Kitch and is quite similiar to yours. You might want to check the archives for that. John
      • jim cear
        Re: 63 shp timing
        Dimple is aligned with the rotor tip. After rotating the dist. shaft one tooth CW the vac. can is now on the coil bracket. Should I still rotate the gear 180*?
        • G B.
          • December 1, 1974
          • 1407
          Yes *NM*
            • 15610
            Re: 63 shp timing
            Do you know the mfg./part number of the camshaft. Is it an aftermarket design or an OE reproduction?
