C3 Unknown wires - NCRS Discussion Boards
C3 Unknown wires
  • Gregory G.
    • August 31, 2004
    • 107
    C3 Unknown wires
    I am in the process of rebuilding some A/C switches in my console and getting my clock & radio repaired. I noticed a plug that was not connected to anything. It is a two connector with 1 solid purple wire and one purple with white stripe. The chassis service manual shows the connector but does not show what is suppose to be connected. Does anyone know what it is for?
    I have a 1970 L46 4spd A/C PW AM/FM Stereo rear defogger.
  • Stephen B.
    • April 1, 1988
    • 876
    Re: C3 Unknown wires
    Those are for an automatic transmission car. I just recently put a new wiring harness on my '70 L46 4 speed car and had the same question.
    • Gregory G.
      • August 31, 2004
      • 107
      Thanks *NM* *NM*
      • Stephen B.
        • April 1, 1988
        • 876
        Re: Thanks
        My pleasure. What does "NM" mean?
        • Harmon C.
          • August 31, 1994
          • 3228
          Re: Thanks
          NM=No Message That makes the post a zero. Sometimes their is a message ahead of the NM but my pleasure means nothing.
          Lyle
            Re: Thanks
            When you post a message with no text, only using the "Subject" line, the forum software automatically adds a "NM" to the end of the subject line, to indicate that there is no text message so you don't have to "open" the message.
            • Stephen B.
              • April 1, 1988
              • 876
              Re: Thanks
              Thanks for clarify.
              • Vincent F.
                • August 31, 2006
                • 202
                that plug is for the neutral safty switch on an automatic shifter to be exact
