C2 SB Tach cable length? - NCRS Discussion Boards
  • Dwight P.
    • June 30, 1983
    • 176
    Need to know the correct length of the Tach cable for a Mid-year SB.Replacements do not have the correct crimp and are 27" which is too long. I do have a source with several used cables, but they vary from 17" to 24".
    Any help is appreciated.
    DP
  • Michael H.
    • January 29, 2008
    • 7477
    Re: C2 SB Tach cable length?
    Dwight,
    The 66 printing of the parts book calls for a cable housing, part number 3866136, that's 23" in OL length. The shaft dim is 24 1/8".
    • Mike McKown
      same subject, different question
      Would you say there is one cable for a FI and one for Carb?
      • Michael H.
        • January 29, 2008
        • 7477
        Re: same subject, different question
        Pretty sure the carb/FI cables are the same part number Mike. (Although the 63-64 would have been a different number than the one I posted above) I'll double check and post the original number for 63. Think there may have been a 1st and 2nd design for 63.
        • Alan Drake
          The 63 1st design was 6409130, lenght of 25 1/8
          63-64 2nd design was 6409507, lenght of 22 1/8
          Also found one for 63-67 pn 6476986, lenght of 24 1/8 may be a service replacement. And for 64 3844016, unknown lenght.
          65-67 3866126, lenght of 24 1/8
          These lenghts are all the cable lenghts NOT the casing!
          Now does anyone dare to ask for the color!
          Hope this helps
          • Joe R.
            • March 1, 2002
            • 1356
            Long Island Corvette has a repro tach cable with a crimp that is very close to the original design. It's a lot closer than some other repro cables I have seen. If you order one, be sure to tell them you want the "correct" design. I think they may have two versions available.
            • Dwight P.
              • June 30, 1983
              • 176
              Joe:
              Thanks for the info. I will give them a call.
              DP
