I am currently doing a frame on rebuild of a 68 coupe. This car was minorly crashed sometime between 80 and 85 as it was last registered in 85ish and was wearing a very poorly grafted 80-82 style bumper up front. The rest of the front fiberglass was in generally poor condition and I decided to replace it as I already had two new fenders (see below). I have repainted the frame (except under the tub on top) a semi gloss black and am in the process of freshening the front and rear suspension with new bushings. All hard parts were in good condition with no slack. All control arms are being painted off the car. My question is what color should the front coil springs be painted? I have found elsewhere in the archives that Krylon dove grey #1605 is correct enough for the rear spring atleast on C2s. Does this apply to C3s? Is this the same color as the front springs? I do not hope to achieve NCRS standards this go round with the car as I am on a bit of a budget, but would like it to be presentable and not glaringly wrong. For now, it will be a driver. I do have the original 327 and turbo 400 to go back in. And I am planning to check my casting numbers on things like brake calipers before I blindly turn them in as cores. When I bought the car I received two NOS GM press molded front fenders (a few cracks from storage but definately useable) so I plan on purchasing a PM hood surround. The hood is fine, original and already prepared for paint. I can reuse my passenger side inner fender but the driver side was damaged in the crash. Also, what is everyone using to reseal the seam between the firewall fiberglass and the front hoop? My windshield frame is not rusty but the (aluminum?) rivets that hold the firewall fiberglass to the hoop have corroded and gave way allowing the firewall to seperate slightly. I plan on coating this area with a rust preventative before reattaching the firewall but did not know what sealer is correct or what will pass as correct. I don't want to shoot myself in the foot doing something now that i would have to undo at considerably more expense later if it only cost slightly more to do it "correct". Are the rivets hardware store pop rivets? Sorry for the long winded post!
Eli
Eli
