I need some help with in determining the proper order for plug wires. To make sure I have my information straight, I have a 62 with engine stamp F0601RC which should be a standard 250HP 327. The firing order on the manifold is 1-8-4-3-6-5-7-2. The cylinders starting front to back on the left side should be 1-3-5-7, and on the right side 2-4-6-8. The distributer should have the number 1 just slightly to the right of the front center line. The car has been running fine but recently started to idle a little rough so I thought I'd check the timing. It seems the my plug wires are laid out starting from slightly to the right front of the center line 4-3-6-5-7-2-1-8. I tried switching the wires to the configuration it should be and the car didn't even run. I switched them back and it runs fine. How can this be possible? Could I have the wrong distributer? Also to note: the timing light only lights up the timing mark when on the number 1 plug wire,( which is in what should be the # 7 position on the distributer) and on the number 6 wire, (which should be the # 4 position). Am I missing something? I hope I described this well enough, please let me know if anyone has run into this.
John
John
