C-2 1965 Power Antenna Removal - NCRS Discussion Boards
  • David H.
    • October 25, 2006
    • 92
    I've got rear exhaust. My power antenna doesn't work (although I can hear electric motor engage when I toggle the power switch). When I'm under car, I can barely see the mechanism, much less get my paws up there to do any meaningful work. I've tried working my hand around the inside wheelwell with the same lack of result. Is there a secret I don't know about or do I need to disconnect my exhaust to work on this bugger? Thanks for any help.
    David Hobby (46447)
  • Willard M.
    • August 31, 1979
    • 422
    Re: C-2 1965 Power Antenna Removal
    On my 66 coupe I faced the same problem getting it ready for a paint job. Once I accepted the fact that I needed to take apart the exhaust system on the left side it became a fairly easy job. I used a device purchased at Carlisle to seperate the exhaust pipe. Basically it is two clamps that tighten on seperate pieces of pipe and then a screw system pushes the two ends away from each other. Maybe the job can be done with the exhaust in place, but it sure made the task easy with room to work.
    Bill #2659
    • David H.
      • October 25, 2006
      • 92
      Thanks Bill. I'll do that. I was reluctant to get under there with a torch.
      David
      David Hobby (46447)
      • Dave K.
        • November 1, 1999
        • 951
        I just replaced the antenna on my 66 roadster. Thanks to some guys on this site I have a service bulletin that describes the process. I just loosened the left side muffler and the rear exhaust panel. The muffler dropped enough and pushed out of the way to get clearance to access the antenna. I managed but it was a challenge.
        Dave K.
        • Wayne M.
          • March 1, 1980
          • 6414
          Here's the TSB Dave's referring to
          By Jan '65 GM knew it was a puzzle for dealer R & R, so they printed these instructions (sans drawing). Guess they still couldn't figure it out, because they repeated it, as below, in June 1966 issue of Chevrolet Service News.
          • David H.
            • October 25, 2006
            • 92
            Re: Here's the TSB Dave's referring to
            Many thanks!!
            David Hobby (46447)
