bring back original gloss - NCRS Discussion Boards
  • Denny J.
    • November 1, 2000
    • 244
    1972 original petwer silver Lacquer paint.What to use to bring back the shine
  • Jim T.
    • March 1, 1993
    • 5351
    Re: bring back original gloss
    take a look at www.meguiars.com and find out what Meguiars recommends for paint restoration. They have a lot of products that are not normally found on auto parts store shelves that can help old paint.
    • Lyndon S.
      • April 30, 1988
      • 1027
      I like to do it by hand and doing so I use #7 from Meguiars, also you could try a 3M rubbing compound. I used it the other day on paint and it worked out really nice. also after the #7 or the 3M rubbing compound use a new product from Meguiars called Scratch X. and that should give you a real good shine with a orgianl laquer. start with a good wash and then work a section at a time by hand is the way I do it. when you use polish or rubbing compound the trick is to not use a lot of hard rubbing, start out frim and lighten up as you polish. you should use cotton other stuff will scratch. good luck
      Kelly
      • Jim T.
        • March 1, 1993
        • 5351
        3M rubbing compound could be to harsh. I painted my 70 Corvette with Dupont lacquer in 1991, after the fresh paint dried I wet sanded with different very light grades of sandpaper and used Dupont polishing compound by hand and then hand applied Meguiars #7. The Dupont polishing compound did a great job on the new lacquer paint.
        • Dave S.
          • August 31, 1992
          • 2918
          Denny,
          When I bought my original paint 71 LT-1 Steel Cities Grey car I thought the paint on the hood unsalvageable. Hoods with original paint are especially sensitive on LT-1 cars due to the hood stripes. I used the Mothers Clay Bar system and the results were outstanding. Now the hood looks like the rest of the car.
          • Wayne K.
            • December 1, 1999
            • 1030
            Denny,
            Check these two places too.
            Car Care Specialties offers a wide selection of premium car detailing products from industry-leading brands. Find everything you need for interior and exterior car care to achieve professional results. Shop now for your car's perfect look!
            • Warren L.
              • February 1, 1990
              • 85
              find your self a top detailer to find out what you have, he may do some testing and then let you know what can be done.
              Warren
              • Alan Drake
                Try www.autopia-carcare.com and also do a search on corvetteforum.com for some discussion topic.
                It takes a lot of work, but it can be done if paint is still there.
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  BC/CC Urethane Will Bring Back The Shine! *NM*
