First I would like to thank everyone for the past info they posted on C2 half shafts.
FYI, I found two numbers on one of the flanges that bolt onto the axle (the one that gets bent somtimes). Both numbers are in the center by the 1 1/2 hole. One appears to be 3843018 (the last number is very dull) While the other number seems to be GM298, however that's very, very dull. If I have not read the numbers correctly please let me know.
The second flange; can not find any numbers, it was the drivers side which showed less details than passanger side.
Did not find any paint marks, however on one half shaft two 3/4" tear drops stand out on shaft since they are very shiney. Said area is smooth and looks brand new still - so either protected by heavy layer of black out or a so called inspection mark (these inspection marks seem to last longer than the black out)
Removed all rust with RidRust that was slow, however does not destory any details.
