Re: Anodizing
Jeff:
Although the NCRS judging manual states that the dull recessed areas of the N14 sidepipe covers are painted dull aluminum, I suspect that this is incorrect. In the process of polishing out some deep scratches with fine emery, I had to break through a hard surface layer (likely the oxide deposited from the anodization process) before the abrasive would start cutting through the scratches. I found this same condition on both the shiny and dull areas of the covers. At this point, it seems that the raised ribs were highly polished, and the recessed areas were left satin finish, then the whole cover was anodized to offer corrosion protection.
If you have any info on the anodizing process, or know of a shop that can do this, I would welcome the info. For now, I'm going to get more info. so I can do the job properly.
Joe
Jeff:
Joe
