valve covers - NCRS Discussion Boards
valve covers
  • John Araujo
    valve covers
    Hello All,
    Does anyone know a good product to polish aluminum valve covers? Iv'e been working on them with a rag and mothers aluminum polish and they look better but still not real good. I was hoping for maybe something I can spray on instead of using a toothbrush in those tight fins.
    John #43736
    Re: valve covers
    When you 'polish' factory original cast aluminum valve covers, you wind up removing their 'as cast' surface skin which experienced judges routinely detect as an originality issue. So, you're on a teeter totter trying to recover condition points at the expense of sacrificing originality points...
    Cleaning off dirt and grease with ordinary carb cleaner and then brightening the underlying aluminum finish chemically with something like the aluminum version of Naval Gel and a SOFT tooth brush is about as much as you can do without sending the covers out for a 're-skinning' restoration.
    • Ken B.
      • May 31, 2006
      • 233
      Re: valve covers
      Try Flitz...I used it on mine and they look great..
