TPI C4 - NCRS Discussion Boards
TPI C4
  • Berndt U.
    • January 1, 1999
    • 72
    TPI C4
    Hello from Berlin
    I have a problem with a TPI Engine. The Car hast not run for more than 6 years.
    And now the engine will not start. I check all the pules and voltage also I check the fuel pressure. Everything thinks OK. I think the injectors stick and the fuel can not run . Must I remove the hole Injectorunit incl. the Manifold ?
    or have somone a better Idea.
    Thanks Berndt
  • Clem Z.
    • January 1, 2006
    • 9427
    the injectors will come out when you remove
    the fuel rails. no need to remove the manifold from the engine. get all new injectors do not even fool with rebuilts unless you are planning to flip the car after you get it running
    • Berndt U.
      • January 1, 1999
      • 72
      Re: the injectors will come out when you remove
      Can I remove the injectors easy ? Must I remove the Air collector and the runners ?
      Thanks Berndt
      • Clem Z.
        • January 1, 2006
        • 9427
        yes
        if you have the older style with the bolt on runners
