More 63 Trivia - NCRS Discussion Boards
More 63 Trivia
  • John D.
    • December 1, 1979
    • 5507
    More 63 Trivia
    Since I have been seeing some new '63 questions for a change I though I would test the waters with one.
    Did you all know that the 63 alternator brace-the long curved one- is much thinner than say the 64 up one? The 63's are really rare since a lot didn't survive since they bent easy. Dr. Mike McCagh pointed this out to me last spring. My 63 FI car has the original brace. Has a big "V" on it. Easy way to spot a repro or later style is to look for the "V". Also you will notice that it's is noticeably thinner. Don't need a mic to spot it. When I was looking at these braces at the ton of 63 fuel cars at the Marlborough regional I noticed that most had the thicker ones on.
    Well have to go finish my Christmas shopping. Merry Christmas and Happy Holidays. You too RJ and MH. Thanks for the good times on the DB. In case you in the DB world don't know RJ, MH, And JD are best of friends. When you see us on the same post you best skip on by as we are at it again.
  • Mike McKown
    I'd have to admit knowing it.
    Only because I bought one for a hot rod project I was working on and it fit perfect. It did break in the adjustment slot. I welded it up and am still using it today.
    • Rob Dame
      Re: I'd have to admit knowing it.
      Were the engines shipped with the brakets attached? Is that why so many are bent?
      • Tom H.
        • December 1, 1993
        • 3440
        Re: More 63 Trivia
        Thanks John !
        Every time I think I've got my car dialed in, I read stuff like this. Looks like mine's got the fat one with no V !! Thanks for the trivia ! One of these days I'll have it right !!
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • John D.
          • December 1, 1979
          • 5507
          Re: More 63 Trivia
          HI Tom, If you can't find an original maybe one of our famours DB guys will email you with a tip. He takes a thick one and takes it and haves it milled down so that it's a thin one. Don't quote me but if I recall they are about .207-.208 thick. Maybe someone can verify this thickness. If not let me know. My '63 is all covered up with two covers to keep warm and has some good plane fuel in it so it can sit for a while. John
          • Tom H.
            • December 1, 1993
            • 3440
            Re: More 63 Trivia
            Thanks John !!
            Just gives me some more fun stuff to hunt for at the swap meets !! Merry Christmas to you. Looking forward to a 2007 full of 63 trivia ! Keep it coming.
            Tom Hendricks
              Rob -
              Nope, that adjuster bracket was installed at St. Louis after 1956.
              • Chuck G.
                • May 31, 1982
                • 2029
                Re: More 63 Trivia
                Not only are they thinner, but as I recall, they also "flare out" up near the adjustment slot, i.e., they're "wider" in that area. Chuck
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: More 63 Trivia
                  Chuck, So the flare out area so to speak would prevent the boys from "thinning" out the thicker ones. CC would spot the thinner cheater ones probably. Take care, John
