66 Coupe Window Channel - NCRS Discussion Boards
  • Clark D.
    • August 31, 2004
    • 50
    I am replacing the top and rear window channel on my 66 coupe. I purchased the prebent window channels from one of the major suppliers and attempted to install. It appears the clips do not line up with the slots (holes) in the door as several clips are way off. Does anyone have any experience with this replacement? Are some of the window channels better than others? I would appreciate any tips.
    Clark #42490
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 66 Coupe Window Channel
    When I replaced my channels I found that the new clips were too thick to go into the holes. I ground them off to appear more like the originals. I don't recall having a hole alignement problem. They are left and right, as one side of the channel chrome is different than the other side. If you have an alignment problem I believe you can remove the clips and reinstall at the correct location.
