Has anyone ever seen or heard of an original ignition coil that has the "202" and "12V" oriented 90 degrees clockwise from the Delco-Remy embossed on the Baklite top? The "202" and "12V" is oriented directly under the positive terminal.
I believe that this coil is the original coil that came from the factory, but I have checked pictures and the discussion board archives and find no reference to this style of orientation.
Installing the coil with the terminals oriented as all of the Nolan Adams pictures show, the "202" and "12V" will be hidden behind the coil bracket.
DP
DP
