Same as post below--just trying another method to post pic--thanks for your patience.
71 LT-1 block
Re: 71 LT-1 block
Mike,
I don't see any picture. Try these instuctions that were posted the other day.
Copy the below text and paste it into Word for future reference.
Kurt
Picture Posting
Posted By: John Waggoner #107
Date: Monday, 11 December 2006, at 11:35 a.m.
In Response To: Re: 1970 LT-1 Rescued (Jim Sears)
Bunky,
You need to get the URL to your pictures. Go to photo the picture at photobucket. See how the page has a lot of other junk besides the picture. That is because the URL that you are using calls a page, not a picture. Here is the URL to the picture: Right click on the picture in photobucket and then choose Properties from the pop up menu. In the properties copy the Location. You may have to click and drag to get all of the text as it scrolls off of the side of the box. Once you have selected the location and it is highlighted press the Clrl and c key at the same time. You have just copied the URL. Now go back to your post message page. Select the box on the Post Message Form for URL and press Ctrl and v keys at the same time to paste your URL into the box.
Fill in the rest of your message.
Now this is important for anyone entering photos in their posts. Click on the Preview Message button instead of the Post Message button. Now you can see before you post your message if it is going to show up or not. You can make changes and try Preview Message again and again until it shows up correctly. Then click on the Post Message button.- Top
Re: 71 LT-1 block
Mike, the "Optional Image URL" line is pre-populated with http:/ . If your link address already has the http://, then be sure to delete the http:/ in the "Optional Image URL:" line before pasting your copied link address.
The result below was obtained by copying your URL from your original post, deleting the http:/ in the optional image line, then pasting your URL exactly as shown in your post. A small detail, but that's what has to be done.
Attached Files- Top
