64 instrument panel - NCRS Discussion Boards
64 instrument panel
  • Joep F.
    • March 1, 2006
    • 40
    64 instrument panel
    What should be the correct colour of the rings around the '64 instruments?
    Should it be bright silver or more a goldish glossing silver?
    Thanks, Joep
  • Jim W.
    • April 1, 2006
    • 228
    Re: 64 instrument panel
    Joep, The inside and outside edges are a frosted silver paint look and the thin line facing lip is polished chrome look.
    • Jim L.
      • 79
      Joep,
      I'm doing my 63 which is the same in most respects. The paint of choice that more closely matched the original is..... KRYLON # 1403 DULL ALUMINUM. It looks great. Be shure to shake the rattle can for about 2-3 min. for a better even coverage without blotches. Then after it's dry, scratch the paint off the edge to expose the crome with your finger nail or a pop-sickle stick which has been soaked in lacquer thinner and wiped off, just leaving a vapor left to remove the paint off the edge. Clean the paint off stick and repeat process.
      Two cents worth of help only.
      Jim
      Jim Lennartz - FWIW
      1963 SWC
      Duntov Award
      Bloomington Gold
      Gold Spinner Award
      Triple Crown Award
      Platinum Award in Class
      Best Restoration in Show
