7 and 1/4 inches
From the front surface of a bolt threaded into the rear hole to the lip of the front retainer. On my end-of-January built 1970. I doubt the measurement will be any different on any other C3, but WTFDIK. It could have been 7 and 5/16 -- depending on how I tilted the bolt. Given the only thing I could get in there was a tape measure, accuracy is not real high.
This dimension will NOT relate to any dimension on the battery or on the measured print of the battery that was published in The Restorer.
Just a suggestion -- get a couple inch length of 3/8-inch rubber hose. Almost any kind will do, but I think the thinner the wall the better. Slit it along its length and slip it over the lip of the front retainer. Install the battery. I know one shouldn't have to do that, but the chances of a judge seeing it will be low and the functionality high. Like Joe, I never had to do that with a real Delco battery, and I have had dozens of them in there.
Whether the reproduction battery is an R79W or an R89W is a function of the sticker on the top. They only made one case in reproduction -- mould costs being what they are. There are other differences between a real R79W and an R89W, according to the production prints, than the sticker, but given the location of the battery in the C3s and the effort to see those differences most judges take the easy way out.
