If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I HAVE A 1962, 300 HP, POWERGLIDE I'M TRYING TO FIGURE OUT WHAT EXHAUST MANIFOLDS WERE USED ON THIS APPLICATION, THE NCRS BOOK SAYS CAST# 901 FOR LH & 902 FOR RH, I HAVE ALSO RESEARCHED IN THE CHEVY PARTS BOOKS THEY ALSO COME UP WITH THESE NUMBERS EXCEPT FOR POWERGLIDE, SHOULD THEY BE CAST# 965 FOR LH & 556 FOR RH THESE ARE THE 250 HP MANIFOLDS IS THIS CORRECT, AND IS IT BECAUSE IT IS A POWERGLIDE? ALSO DID THIS APPLICATION USE A CROSSOVER PIPE & WAS IT 2" OR 21/2". I DON'T CARE WHAT SET UP IS USED I JUST WANT IT CORRECT.
THANK YOU FOR YOUR HELP.
Mick--
Please turn off the caps--that's shouting, and we prefer that people don't shout.
62 300HP cars had 901 and 902 manifolds. I've owned two of them, and they were both original cars.
Mick I have a '62,300 hp,powerglide car also. I took my original manifolds off because of excessive pitting(not really that bad)installed GM replacements with same part # but different casting characteristics, cost me four points for the education at San Antonio.My car has crossover pipe and 2 1/2" pipes. Good luck.
Yes, and yes. I should have mentioned those two were powerglide--I've had 28 62's in all. 300HP cars used crossovers--that's the way they were built--no optional engine in 62 was without crossover.
I agree with Mike and Terry; a 1962 300 hp engine, with or without Powerglide, used the GM casting #3797901 and 3797902 exhaust manifolds. These are 2-1/2" outlet manifolds.
What generates the confusion here is that things changed for 1963-65. For 63-65, the 300 hp (L75) engine with manual transmission used the same manifolds as described above. However, for 300 hp (L-75) engine with Powerglide used different manifolds with 2" outlet size.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
