C1 Steering Box Side Cover Gasket - NCRS Discussion Boards
  • Pierre J.
    • July 31, 2000
    • 193
    Does anybody have a part number (from Fel-Pro or others) for the side cover gasket on a C1 steering box? I know I can order them from most Corvette parts suppliers but I would like to get it from local places such as NAPA....
    Pierre
    #34410
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C1 Steering Box Side Cover Gasket
    buy a roll of gasket stock at napa and make your own gasket. rough cut the gasket material a tad larger than ya need, place that piece of material on the steering box and holding it firmly in place gently tap around the edges of the material/box with a ball peen hammer. do same with the inside of the box/gasket interface. you'll get nicer results cutting the bolt holes if you have a leather punch. takes about 3 minutes.good luck, mike
