correct boot for alternator 63? - NCRS Discussion Boards
  • Joe C.
    • April 30, 2001
    • 126
    does the correct boot for a 63 alternator have a rib across the top, or is it flat without rib. What is correct type? please help. thanks
  • Mike M.
    • May 31, 1974
    • 8365
    Re: correct boot for alternator 63?
    four ribs or in other words, a pair of ribs that cross in their centers.junkyards full of them-gm pass cars of early 60's. mike
    • John D.
      • December 1, 1979
      • 5507
      Joe, My 63 had an original wiring harness in it so I had the original alternator boot which we easily put on the new repro harness. Yes it has a cross effect of ribs like Dr. MIke just explained. I see variations of this boot so you have to be careful. My original one had a rather large hole for the boot to slide onto the harness. Most of the junk yard ones I have "seen" had a small hole therefore making it a tough job to install on a new harness. From time to time these are on ebay in the $25.00 range. John
      • Joe C.
        • April 30, 2001
        • 126
        thanks for the info- there is one on ebay- I wanted to be sure that it would be correct before I bid on it.
