3904351 Engine
  • Rob Howell
    #1
    3904351 Engine
    Hello,
    Can someone help me with what should be a simple question? Where does the oil pressure sender go on this engine (4 bolt main)? There does not seem to be a logical oriface for the sender to screw in. The block is not for my car--I have a '62. It was priced right though so I bought it anyway. Thanks.
  • Joe Lucia (12484)
    • 42936
    Re: 3904351 Engine
    Rob-----
    The oil sender installs into one of the tappings on the block above the oil filter. However, a special reduction bushing must be installed first. This bushing has 1/2" NPT male threads (which go into the block tapping) and 1/8" NPT female threads (into which the oil pressure line fitting installs).
    • Rob Howell
      Re: 3904351 Engine
      Thanks Joe. This block has two bolts or plugs near the oil filter. Do I need to remove these? WHat is the second one for?
      • Joe Lucia (12484)
        • 42936
        Re: 3904351 Engine
        Rob-----
        Actually, both of them are for an external oil cooler installation (these were never installed in PRODUCTION, though). You need to remove one of the plugs to install the oil pressure bushing. It should be the one that is nearly "centered" with the oil filter cavity. I think that only one of the tappings is for 1/2" NPT and that's the one you want. The other one is, I believe, 3/8" NPT.
