Hi, I have a question regarding door gaps on a 59. A buddy of mine has replaced the damaged front clip on his 59 with a Sermerscheim unit. Now he's moved on the door fit and seems to be having nightmares with the way the doors fit the opening. According to the illustrations in the service manual in section 11-4 figure 8, the gap is to be between 1/8 - to 7/32's. When the door is set to 1/8 at the rear of the opening, it has 11/32's at the front. Overall it fits the opening pretty good but the gaps look bad. It apperas that he'll need to fill in some of this gap at one end or the other. My question then becomes, which is the preffered end of the opening to add fill, and that being asked, what is the best filler method to use? Vette Bond, glass mat and resin combo, or some other glass strand reinforced filler?
Thanks, Mick
Thanks, Mick
