I just received a 68 vette that was in climate controlled storage for over 21 years. My first step is the brakes. I do know one of the calipers was leaking and the car also came with four new calipers and pads in the box. Four questions:
1. Where is the best place to get a replacement master cylinder. I believe I need to get one with the same two letter code the original has.
2. Rubber brake hoses to the caliper or braided stainless steel?
3. Any suggestions on cleaning out the metal lines to each of the four corners of the car?
4. DOT 3, DOT 4, or silicone brake fluid? Any suggestios on bleeding (pedal, vacuum, power?)
Thanks in advance.
Don Schuette NCRS Member 32294
Thanks in advance.
