My drivers side sideview mirrow on my 76 will not tighten. I took the allen screw out, and the monting plate is tight. The screw and mirror itself are in excellent shape! Can someone help me with git rid of this problem? As always "Thanks"
C3 Lose Sideview Mirror Wobbels
Re: C3 Lose Sideview Mirror Wobbels
Having a original owner 68 and 70 I have replaced the original sideview mirrors on both cars. I did encounter a mirror replacement once where the mirrow would not become secure when the allen head screw was tightened. Switched bases and the mirrow mounted correctly.- Top
Agree!
I've seen several cases where the existing base didn't provide a correct interference fit between the mirror and the mounting gasket resulting in an installation where the mirror 'wobbled' relative to its stance on the door...- Top
