In the 3rd edition of the 63-64 Judging Guide, page 25, sect 3B, auxilary hardtop, it states that;
"WHEN THE HARDTOP IS CORRECTLY INSTALLED, THE LOWER PORTION OF THE BOLT,A BLACK RUBBER WASHER, A METAL CADMIUM OR ZINC PLATED WASHER AND A 7/16" CADMIUM OR ZINC PLATED NUT ARE VISIBLE ON THE UNDERSIDE OF THE DECK LID".
If I remember correctly, isn't the rubber washer supposed to be in the instrument panel compartment when the hardtop is installed? I thought the rubber washer was only used under the reinstalled mounting bolt head when the top was removed. Wouldn't this washer be a judged item included in the contents of the I.P. compartment?
Also, the 1/4"-20 mounting bolt is supposed to have a small rubber tip at the end to prevent scratching the painted surface of the deck lid during removal/installation of the top assy. Should this rubber tip be included in the items to be judged? Thanks.
