On page 131, section 21, engine compartment, of the 63-64 Judging Guide, it states that;
"ALTHOUGH THE JOINT BETWEEN THE INNER FENDER AND UPPER SURROUND MAY BE A POOR FIT, IT HAS A FINISHED LOOK".
This is describing the bond between the fender skirt and upper fender as seen with the hood open. When these two panels are bonded together, some of the bond material is forced out of the junction and this excess bond is then ground off with a very course round rotating disk grinder. The text above suggests that this surface was then smoothed, or sanded, to create the finished look described. Would this be typical of a 63-67 car?
