53 -55 trans tunnel help - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    Can anyone provide me some measurements? To the center of the acorn nut that holds the shifter cover on, could I get measurements from the floor and then the base of the seat separator when it meets the trans tunnel? I'm trying to locate the center of the shifter hole so I can glass in a replacement piece I have on order. Mine was hacked up for a 4 speed when I got the car. If I have these two measurements I should be able to get the new part in the right location.Thanks in advance, Mike.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 53 -55 trans tunnel help
    Wait for the replacement piece add the shift to it then the trans rod from the shifter to the trans linkage then try to locate it's position
    • Michael L.
      • July 31, 2005
      • 562
      Roy, that would work if I had the linkage. That was missing with all the other transmission parts. I palnned on fabricating one once I had everything put back together. If I know the measurements, I can fix the trans tunnel while the body is off the frame, then fab the linkage or buy one.
      Mike
      • Roy B.
        • February 1, 1975
        • 7044
        I would think the piece your getting should give you an idea of wear it should fit.
        • Chris S.
          • January 1, 2000
          • 1064
          When you rec the peice
          you will see there is only one place for the shifter to go
          I am sure we can send you pic of one without the carpet
          you will see what I mean.
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
