The positive cable I received from Lectric Limited has the numbers "6286180" on it. The negative cable has nothing printed in it. The judging guide says the positive cable should have "6286182" on it and the negative cable should have "2979821" . Lectric Limited says the juging guide is incorrect.
Which is correct, the guide or Lectric Limited?
Thank you,
Randy
Thank you,
Randy
