My car lost a couple of points at the National for an incorrect tach cable. I ordered one from Long Island, and it has all of the correct crimps and knural nuts that the judge said were necessary.
The new cable slipped through the firewall grommet very easy (I was expecting some difficulty) and the knurl nuts went on with no problem. But when I stared the engine, no RPM on the Tach. I re-set the cable several times on both ends and occasionally the Tach would read RPM's for a few seconds and then zero. The new cable appears to be the same length as the old one and there were no problems with the Tach when the old cable was installed.
Is there something that I am not doing or is there some special trick that is
required?
Any help would be appreciated.
DP
required?
DP
