Water spots, please leave! - NCRS Discussion Boards
  • Phillip E.
    • November 15, 2006
    • 25
    What is the best way to remove water spots from the glass T-tops?
  • Phil P.
    • April 1, 2006
    • 409
    Re: Water spots, please leave!
    lime away---or anyother type tile cleaner---zep from home depot---if they are light---vinigar water 50/50 mix will work
    • David M.
      • September 30, 2004
      • 515
      CLR far superior! Keep it off paint. I live in a heavy mineral water area and this is the only thing that does the job. Gotta let it sit.
      • Alan Drake
        If CLR does not work (doesn't work onall minerals) try some alcohol and razor blade (careful) or the vinagar solution (that can also be used on paint to do the same) or some Clean Shower (by Arm & Hammer)which works for me where CLR does not (different minerals).
        Good Luck and post results.
          • 15573
          I have found clay -- the same as used on the paint finish -- removes water spots. The spots are different depending on the minerals in the water, so try various methods until you find one that works.
          • Terry F.
            • September 30, 1992
            • 2061
            This has been discussed before. I think there actually might be products as an automotive paint store that deals with it. A clay bar might work. I know there are other things too. Terry
