'66 e-brake warning light socket - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I got a 12" pair of curved, hemostats to try to remove the socket from the dash and change the bulb. The socket is plastic, like the "lights" warning light. Before I start pulling on it, does anyone know for sure if it pulls out, like the other metal bulb sockets? I don't want to break it, if it needs to be turned to be removed instead. Thanks....
  • Ken Edmunds
    Re: '66 e-brake warning light socket
    It pulls straight out-don't twist it.
    • Rob A.
      • December 1, 1991
      • 2126
      Ken,
      I got the socket out...that's a strange looking, large round bulb. Murphy's law....the glass bulb separated from the metal. Where exactly do I find a bulb like this?
      • Rob A.
        • December 1, 1991
        • 2126
        Ken,
        Assuming there's a metal backing that I need to fish out of the socket...I assume I should disconnect the battery??
        • Ken Edmunds
          The bulb is a # 257, it has a built in flasher element. Most corvette vendors sell them. I got some at a local light bulb store.
          ALWAYS disconnect the battery when working with anything electrical and especially under the dash!
          • Rob A.
            • December 1, 1991
            • 2126
            Ken,
            I found a T57 at my local auto store, they didn't have a 257. Will this bulb not flash, as original?
            • Ken Edmunds
              I have never heard of that bulb. If you can't find one email me privately I will send you some.
              • Wayne K.
                • December 1, 1999
                • 1030
                Is #257 also used for the headlight warning? *NM*
                  Re: Is #257 also used for the headlight warning?
                  Yes.
                  • Wayne K.
                    • December 1, 1999
                    • 1030
                    Thanks john. *NM*
