'66 e-brake warning light bulb replacement - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I ordered a 12" pair of hemostats to change the bulb. As it turns out, after removing the right vent handle and the bracket that holds the odometer reset button, I was able to reach up in and do it without using them...in case anyone might need to do the same in the future. (My car has telescopic steering...I don't know if that would make any difference)
  • Rob A.
    • December 1, 1991
    • 2126
    ..you also need to remove the hazard flasher
    warning from the e-brake mount, if installed, to allow your hand in.
