C2 vent window repair - NCRS Discussion Boards
  • Dennis H.
    • August 31, 2005
    • 53
    I must replace the driver side Tee shaft on the bottom of the vent window. Does anybody have any shortcuts or info that I need to know. Also, does the gasket just fit in without any fasteners?
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 vent window repair
    Not sure about the tee shaft. On the convertible the gasket has a few metal tabs built into it. These tabs are press fit into the frame channel. You can pop it out with a screw driver.
    • Dennis H.
      • August 31, 2005
      • 53
      Thanks Bob for your input.
