'55 distributor
  • Michael L.
    • August 1, 2005
    • 562
    '55 distributor
    I took apart my distributor to clean and rebuild. The oiler tube with the felt wick was a solid mass, had to pick it out with dental tools... Anyone know of a suitable felt or other material to replace the wick?
    Also, the orginal pin that holds the drive gear to the shaft was solid, all I see are roll pin repalcements. Any souces? Or make my own out of stock? The ends of my pin were peened, will a roll pin stay in place without peening?
    Thx in advance.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '55 distributor
    Mike write me when I get back I have the felts,on the drive gear find a solid pin the cut and peen the ends or again get up to my house I have many 55 Dist. Good ones there cheap to locate
    • Michael L.
      • August 1, 2005
      • 562
      Re: '55 distributor
      Thanks Roy! Have a safe trip to Florida. Mike
      • Dave Suesz
        Oil tube?
        My original has a grease cup.
        • Michael L.
          • August 1, 2005
          • 562
          Re: Oil tube?
          David, my engine is a passenger car 265 V8, so maybe the distributor is different. I have a tube with an L bend in it that has an oiler cap on top of it. The threaded end screws into the base of the distributor. The wick is inside the tube and runs into the distributor base to oil the shaft bushing.
          Mike
            • 42936
            Re: '55 distributor
            Mike-----
            If it were me, I'd use the roll pin. In my opinion, the roll pin is a better retainer for the drive gear than a solid pin. At the very least, it's the equal of the solid pin.
            • Michael L.
              • August 1, 2005
              • 562
              Re: '55 distributor
              Joe, used a roll pin this afternoon, worked just fine.
