63 front parking brake cable - NCRS Discussion Boards
  • Tom H.
    • December 1, 1993
    • 3440
    Just installing the parking brake assembly on the 63 and have everything in place. I think I'm missing the front cable clamp. My question is, as you are looking at the cable as it comes out of the firewall and into the engine compartment. Where is that first cable clamp mounted ?? It appears to mount near the steering box at the frame. The AIM isn't clear on the mounting. Can anyone confirm the clamp position ? Thanks !
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 63 front parking brake cable
    It's been several years since i installed the cable in my 63 so i'm going on memory. I believe there is a threaded bolt mounted on the frame next to the steering box. The clip attaches to this threaded stud.
    • Tom H.
      • December 1, 1993
      • 3440
      Perfect !! Thank you.
      Tom Hendricks
      • Timothy B.
        • April 30, 1983
        • 5177
        Tom,
        To add to what Bob said, the clamp uses one of the steering box mounting bolts. I think it's the lower bolt, if you have a AIM it is shown.
