1962 Fuel Line Install - NCRS Discussion Boards
  • Kennith H.
    • December 1, 1981
    • 52
    I'm preparing to install new brake lines and I have read in several different places that this should be done with the body off (or elevated). In looking at the illustration in the Assembly Manual it appears the lines run down the insides of the frame and only go to the top of the frame at the front corners and under the frame at the rear. Am I missing something?
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 1962 Fuel Line Install
    Ken
    It can be done with the body on, just much easier with it off. If my senile old brain remembers correctly, the routing thru the frame crossmember is the tough part with the body on. As they say were there is a will there is a way. Good Luck and let us know how you make out. It would be a good article for the Restorer.
    • Kennith H.
      • December 1, 1981
      • 52
      Thanks Terry - with the difficulty of raising the body again I'm game for trying the body-on approach.
      • Terry R.
        • March 1, 2005
        • 359
        I put new brake lines on my '62 with the body on a few months ago. The hard one was the crossover under the radiator,if I had to do it again I would take off at least the shroud. Have fun!!
        • Kennith H.
          • December 1, 1981
          • 52
          Terry, Thanks for the tip.
