C1 Signal Flasher - NCRS Discussion Boards
C1 Signal Flasher
  • Jimmy J.
    • May 31, 1988
    • 304
    C1 Signal Flasher
    What is the correct signal flasher for a 1959? Thanks, Jimmy
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Signal Flasher
    Generally a ZN232 (Signal Stat)
    Bill Clupper #618
      ZN-232 *NM*
      • John R.
        • September 30, 1999
        • 288
        Re: ZN-232
        I understand that you need special bulbs to operate correctly with a ZN232. With the currently available bulbs, the flasher cycles to rapidly. Does anyone have any suggestions for this problem?
          Re: ZN-232
          You don't need 'special' lamps, you just need correct originals. Check your copy of the owners manual and the lamp number will be called out.
          If memory serves the factory originals were No. 1034 lamps and these were 'replaced' later in time with a more efficient, drop-in, replacment (No. 1157). While similar in candlepower rating and physical geometry, the 1034 lamp has a less efficient filament and therefore draws slightly more current. The blink rate of these old flasher modules is a function of branch circuit current flow...
          • John R.
            • 288
            Re: ZN-232
            Thanks for the response, Jack. I have been unable to find the 1034 lamps. All the usual sources show them as being replaced by 1157. Does anyone know a source for the originals?
            • Jimmy J.
              • May 31, 1988
              • 304
              Jack, Bill are they still available across the counter? Thanks to both of you for your response. Jimmy
