frame off near completion, having problem with the gauges they light but do not dim. tried using another headlight switch same results.
c-1 1957 dash
Re: c-1 1957 dash
Greg -
Make sure the wire terminals are properly idexed in the headlight switch connector; the gray wire terminal (which feeds all the dash lights) should be connected to the output side of the wirewound resistor on the dash end of the switch that controls the dimming function.- Top
