Yesterday I began the day ready to start removing parts and pieces in prepartion of my engine swap. This is a 66 Coupe 327/300 4 speed. So, I got the car on jack stands, got my reference books nearby, got my tools ready, all is good. First thing I will attack is removing the drive (propeller) shaft, no problem. Study the Chassis Service Manual, wiggle myself under the back end of the car and remove nut on the underside of the biscuit. Great, off to a good start. The next step says to 'pry the carrier downward to relieve load while removing the two center mounting bolts from the carrier front support.' OK, seems easy enough. The manual then states, 'To pry carrier downward insert crowfoot end of a pry bar through the opening in the carrier front support, hooking end of bar over top of the center mounting bolt pad cast in the underside of the carrier.' At this point I said, HUH?!!! What opening? Top of center; underside of carrier? What??? I must have re-read this thing a thousand times without ever getting anything done. I have a crowbar but there must be a specific size required. Also, if I finally get this crowbar hooked somewhere what am I leveraging against? Maybe I just need a picture. Today I'm licking my wounds an rethinking my next move.
So here I am, looking for any help anyone can give and thinks in advance everyone.
