C2:67 Alt Belt 1103758 - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3803
    What's the length of the alternator belt for a 67 327/300 base engine, no AIR, no A/C.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    Re: C2:67 Alt Belt 1103758
    Jerry----
    The GM #3847710 belt used for your application was 53-1/4" in total length. Keep in mind that this was a 3/8" wide belt. Most current GM replacement belts are 7/16" wide and require a slightly longer belt since the belt rides slightly higher in the pullies.
      Jerry -
      The Quanta belt they specify for that application works fine - puts the alternator tension bolt about 1/3 of the way from the inboard end of the slot in the adjusting brace.
