Proper C3 Oil Cap - NCRS Discussion Boards
Proper C3 Oil Cap
  • Rob H.
    • April 30, 2006
    • 121
    Proper C3 Oil Cap
    Can anyone confirm if this is the correct oil cap for my '69 L36? It has an "S" on the pin and two sets of grooves.
    Much thanks in advance-
    Best,
    Rob
    Re: Proper C3 Oil Cap
    Rob------
    No, this is a later service replacement, Stant-manufactured cap. In fact, I believe that you can still purchase caps of this configuration to this very day. It may have been used on much later Corvette small blocks with aluminum valve covers, but it was not used for the pre-73 period.
    The original cap had only a single relief impression for the rivet. It was not a "multi-tier" impression like this one.
    Some folks get real "hung up" on the "S"-stamped center rivet and/or the "SMC" stamping also found on some caps and lose sight of the MAJOR ELEMENTS of configuration. There are LOTS of caps with the "S" center rivet stamping and many with the "SMC" logo that are otherwise completely incorrect for a Corvette application.
    • Rob H.
      • April 30, 2006
      • 121
      Thanks for the info Joe -- I was afraid that was the case. My original cap leaks slightly and I wanted to get an original replacement...
      Rob
      • Rob H.
        • April 30, 2006
        • 121
        Joe-
        Is this more like it?
        Rob
          Rob-----
          Yes, that looks a lot more like it. However, I'm not sure if this cap is an original or some sort of reproduction. For some reason, something about it does not look quite right.
            • 15573
            It might be the angle of the photo, but to me the depression looks too deep. There also looks like there might be a second logo below the rivet -- or it is a reflection. Original chrome oil caps of this period had only the S in the center.
              Terry-----
              Yes, there is the "SMC" logo and I also believe that this was not seen on the top chrome caps of the period. Non-chrome, Stant caps often had these on the top or bottom surfaces.
              Beyond the above, it appears to me that the primary "vertical" surface of the cap (i.e. where the interior flat surface rises to the perimeter surface) seems like the lower radius is too sharp and, perhaps, the vertical surface is a bit too "steep". It just does not look quite right.
              • Greg L.
                • March 1, 2006
                • 2291
                If it helps, here is the cap from my 69 L-36. I've never had a reason to believe that it wasn't original seeing as I've had the car for almost 20years and it looked as raddy as the valve covers did including some of the pitting that can be see in the one pic. The only obvious tampering that the engine had when I got it was a replacment carb, alternator, plug wires and missing smog. Other than that it looked like a virgin. Oh and I don't see any stampings on it either.
                Please don't tell me in not correct...
                Greg Linton
                #45455
                  • 15573
                  looks good to me *NM*
                  • Rob H.
                    • April 30, 2006
                    • 121
                    Re: looks good to me
                    Strange thing is, the one on my car looks just like Greg's -- BUT the one in the '68-'69 Tech Guide (p. 42) looks like the first one I posted that Joe said is a replacement...confused.
                    Rob
                    • Terry F.
                      • September 30, 1992
                      • 2061
                      Rob,
                      I can send you a picture of a 68 chrome cap on a 390 hp. Let me know. Terry
                      • Rob H.
                        • April 30, 2006
                        • 121
                        Terry-
                        If it is not too much of a hassle it would be much appreciated.
                        Much thanks!
                        Rob
                        • Terry F.
                          • 2061
                          Rob, send me your email to tfringo@aol.com and I will shoot off some pictures. It might take me a while but I will get it done probably tomorrow after work.
