DIFFERENTIAL BRACKET - NCRS Discussion Boards
  • Albert P.
    • April 1, 2006
    • 205
    1964- Is there enough tunnel clearance to remove the through-bolt on the differential support bracket? thanks.
  • Alan Drake
    Re: DIFFERENTIAL BRACKET
    Was unable to remove mine last month, however believed I removed it in the 70's via the hole in the jack storage well. Appears I needed to make existing hole a little wider, so this year I glassed the hole back to normal. The AIM shows that the long bolt, however, goes in from other side, if yours is that way then no hole and entire bracket needs to come down.
    Note; even though the AIM shows bolt in the other direction mine was not! One may ask, why was a hole put in the jack storage if not for bolt access?
    • Stephen P.
      • September 30, 2002
      • 116
      It's not easy, but you should be able to remove it.
